AD650 freq to volt circuit power supply question
Discussion in 'General Electronics Chat' started by Tony Elliott, Feb 4, 2016.
  1. Tony Elliott
    May 8, 2015
    140
    Hello All About Circuits,
    I am looking to power a frequency to voltage circuit using a AD650.
    The power connections are new to me, I know how to power a -15 gnd +15 but it only has a +5 connection. Where do I link the -5 on my bench power supply?
    I'm guessing gnd between -15 +15 or -15? I didn't want to just chance it as the ic is quite expensive and I only have one.
    To see the data sheet
    http://www.analog.com/media/en/technical-documentation/data-sheets/AD650.pdf
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
    You link the negative and positive centre terminals together to make Chip ground, then set the psu to +15/-15 and put the 5v supply negative to the Chip ground and the +5v to the chip.
  3. Tony Elliott
    May 8, 2015
    140
    Ok so, the 5v supply negative links with the ground between the -15 +15. could I link them on a gnd rail on a breadboard?
  4. Dodgydave
    Jun 22, 2012
    5,150
    769
    Can do, or link them all at the psu.
    Tony Elliott likes this.
  5. hp1729
    Nov 23, 2015
    2,094
    232
    To logic ground?
