ad633 frequency multiplier
Discussion in 'The Projects Forum' started by xisco, Apr 16, 2010.
  1. xisco
    Mar 2, 2010
    14
    Hello!
    I am thinking to use an AD633 in order to mix two digital frequencies. I have some questions regarding this device, is it possible to use this device for digital frequencies? I think it is but I wanted to ask to be sure and I don't know if someone could please tell me if by using the schematic in the datsheet for frequency multiplier it is possible to achieve the output with fc+fm fc and fc-fm.
    Thank you very much
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Help us out a bit - what are "digital frequencies'? Are the signals to mix pulses from logic IC's?
  3. xisco
    Mar 2, 2010
    14
    well the digital frequencies ideally in my case should come from IC's however I am in the situation that I am going to have to use two signal generator TTL, for example 6.6 MHz and 6 MHz
  4. t06afre
    May 11, 2009
    5,939
    1,222
    The AD633 is made for analog signal. It will not work very good for digital signal with a high selwrate. Look at figure 3 in the datasheet
