Ad622ar
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Mar 21, 2012.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
  2. crutschow
    Mar 14, 2008
    13,473
    3,361
    If you read the data sheet on page 7, it states the output voltage is referenced to the REF pin potential (i.e. for 0V output the voltage between the output and REF is 0V). Thus for normal operation with a plus and minus supply, you connect the REF pin to circuit common.
    Edit: If you connect REF pin so some voltage, then the output will referenced to (offset by) that voltage.
    TAKYMOUNIR likes this.
