AD595 chip at high temp - what happens...
Discussion in 'General Electronics Chat' started by meestahelectro, Sep 24, 2010.
  1. meestahelectro
    Aug 10, 2006
    28
    I am thinking about using the AD595 chip in conjunction with a k-type thermocouple. the issue is that this will be in an area where there is some serious heat. I can't tell but what effect does heat have on this chip. what if the temp got up to 250 degrees farenheit??? unfortunately this thing sits in an engine compartment that gets very hot. any ideas...
  2. campeck
    Sep 5, 2009
    194
    can you not bury the chip in some high temp silicon?
  3. meestahelectro
    Aug 10, 2006
    28
    I think that is what I would do. maybe encase the sucker i a small block of silicon... do you think that would keep the heat down at the chip. sorry I am unfamiliar with what that would do in the real world.
    the temp reading I need to get is around 950 deg cel, so being off +/- 20 is not a huge deal for me... I just don't know if the chip will function.
    thanks for any insight.
  4. tom66
    May 9, 2009
    2,613
    214
    The AD595 is designed to be operated in an ambient temperature from 0°C to +50°C according to the datasheet.
    250°F is 121°C and this is way too hot. If it works, the readings will be inaccurate.
  5. meestahelectro
    Aug 10, 2006
    28
    what about using the silicon insulator as suggested????
  6. marshallf3
    Jul 26, 2010
    2,358
    201
    Insulation only slows the transfer of heat, in time it will all reach and equilibrium temperature.
    You're just going to have to mount the chip elsewhere.
