AD 9959 programming
Discussion in 'The Projects Forum' started by pratapkollu, Jun 7, 2012.
  1. pratapkollu
    Thread Starter Active Member
    Dec 13, 2006
    42
    Hai
    I got the AD9959 evaluation board and its working fine, I can generate 300 kHz and 600 kHz signals.
    (Single-bit serial mode (2-wire mode)
    Now i wish to buy the 9959 chip alone and integrate it in my pcb, which pins are used for communication
    I assume SCLK, CS BAR, SDIO_0,SDIO_3 PINS should be connected to USB port of computer?
    can this pins be connected via mini B USB terminal to computer USB port?
    does the same software which is used to control/program eval board is useful now?
    please clarify
    thanks and regards
    Pratap
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Doesn't our evaluation board have a schematic?
