Ad 7874r
Discussion in 'General Electronics Chat' started by rishividya, Jan 8, 2014.
  1. rishividya
    Jan 8, 2014
    Dear All
    Good Evening
    Kindly confirm if faulty ADC ie AD 7874AR can cause wrong current measurement as we are getting a fault "Current measurement wrong" in a digital drive controller and we suspect this might be due to faulty AD 7874AR
    Regards,
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    Sure.. a faulty ADC can cause incorrect readings..
    But so could a fault in really ANY component in that circuit.
    Without a complete schematic and a much more detailed explanation of the problem you/we are just guessing.
  3. rishividya
    Jan 8, 2014
    We have swapped ADC ie AD 7874AR from similar drive but still same error
    We are checking drive at Lab by just giving 24VDC that means there is no load on drive and hence we suspect wrong error due to faulty sensing ICs
    We also find XC3020 on the PCB , can faulty XC3020 also cause wrong error related to current measurement, kindly confirm
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    oh my...
    Lets try this.. fun time...
    Oh wait you have the XC3020... Yes ..Thats the problem. However you cannot repair it. You need to buy a new complete replacement drive.
    tshuck likes this.
  5. rishividya
    Jan 8, 2014
    Thanks for ur support
    Even we swapped XC3020 from another ok and similar drive, still could not fix error
    All ressistors, diodes etc checked found ok
    Details of other ICs not legible hence unable to proceed further
    Regards
