AD-620 Wave Amplification
Discussion in 'The Projects Forum' started by Farrukh12, Apr 3, 2013.
  1. Farrukh12
    Mar 27, 2013
    6
    Can the AD-620 be used to amplify a triangular or sin wave. If yes how?
  2. crutschow
    Mar 14, 2008
    13,477
    3,362
    Yes, if the signal frequency components are in the frequency response range of the amplifer. A triangle wave has high frequency Fourier components that must be amplified to accurately reproduce the waveform.
    If the frequency conditions are met then you just apply proper supply voltages to the amp, add a gain resistor for the desired gain, and connect the signal to the differential inputs. If you have a single-ended signal then connect the unused input to signal common.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    AD-620 is also an instrumentation amplifier. So I suggest some searching on Google using the term "instrumentation amplifier"
    Why do you want to use an instrumentation amplifier. We could give better help if you tell us what you want to do.
  4. Farrukh12
    Mar 27, 2013
    6
    I am creating a triangular wave using transistor and a Hex Schmitt Trigger.
    The frequency of my wave is between 20-30 kHz, but my amplitude is very low appoximately 330 mV. Thus I want to amplify it or can anyone tell me a better way to create a triangular wave of 20-30kHz and 3V amplitude
  5. t06afre
    May 11, 2009
    5,939
    1,222
