Actuator PWM
Discussion in 'General Electronics Chat' started by Dritech, Jul 7, 2013.
  1. Dritech
    Sep 21, 2011
    756
    5
    I am planning to build a Robotic arm using actuators. After doing some research I found out that you cannot use PWM with actuators. Is this true? and if so, why is that?
    Thanks in advance.
  2. crutschow
    Mar 14, 2008
    13,523
    3,392
    Depends upon the type of actuator. What kind are you planning on using?
  3. Dritech
    Sep 21, 2011
    756
    5
    DC 12V or 24V linear actuator
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    What aspect of the actuator do you want to control with PWM? Speed can be controlled by PWM. Position will depend upon the type of feedback available from the actuator, if any, and a method of using it to compare to the PWM position signal. A secondary feedback device may be required.
  5. Dritech
    Sep 21, 2011
    756
    5
    The reason why I want to use a PWM is to control the motor speed only.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    I that case, PWM is a good way to control the actuator. H bridge with PWM will give you both speed and direction control.
