I'm wondering if someone could help me out with my current project? It's a simple threaded bar attached to a 12v motor with a bearing on the opposing end that will have a Nut welded to some box section in the middle which will be on runners. I bassically need a two way rocker switch to initially activate the solanoid to release the latch and then after a time delay of around 5 seconds, the motor to start turning to move the middle bar. Once the bar reaches the furthest distance It should travel i want it to hit a microswitch to disconnect the circuit. It's a bit of a crude way doing it but i think it will work. Ive put the solanoid latch on a seperate circuit via a relay to try to keep everything seperate. Any feedback would be great, will this work? PS I haven't even looked at polarities yet just wanted to get what was in my head on paper and get some advice. Cheers all.
