Actuator help
Discussion in 'The Projects Forum' started by Slinkycyrax, Sep 28, 2011.
  1. Slinkycyrax
    Sep 28, 2011
    I have an actuator that I need to activate on it's own and extend and then in 60 minutes, reverse polarity on it's own and close. I would need this to continue this on a loop. And suggestions on relays that would help me on this. Thanks in advance, I'm a new at this just so you know.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Do you have any more information on this "actuator"?
    Like, what voltage and current it requires?
    Maximum and minimum currents?
    Does it have built-in limit switches, or do you need to add them?
  3. Slinkycyrax
    Sep 28, 2011
    Thanks for the quick reply. It's an fa-70
    It's requires 12 VDC at 5 amps at full load. Not to sure of the minimum draw. I know it does have a built in limit switch. Here is the link for the specs if that helps at all. http://www.firgelliauto.com/download_file.php?file=16
    Thanks again
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    How are you going to be powering this actuator?
    Are you building your own power supply, or are you considering operating it from batteries?
  5. Slinkycyrax
    Sep 28, 2011
    Currently I have no power supply but my intention is to purchase a converter so that I my plug it into the household
  6. Bernard
    Aug 7, 2008
    4,239
    414
    Then it extends for 60 min., then retracts for a few seconds, then extends again?
    Simple approach might be to use two 555 timer ICs & DPDT relay; first 555 free runs with period of 60 min., at reset it triggers second 555 configured as a one-shot set for retract time + a little safety time margin. Second 555 drives relay [ asuming coil current less than 200 mA ] with normally open contacts set to extend.
    Might want to check post by Dimitris76 also on Projects Forum.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, I'm thinking that Slinky wants it to extend, sit there for 60 minutes, and then retract, and sit there another 60 minutes, and repeat. Is that right?
    If so, a 555 clocking a 14-bit counter that controls a transistor or MOSFET driving a DPDT relay coil could do the trick pretty cheaply. The timing wouldn't be terribly accurate, but I haven't heard how accurate it needs to be.
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    Since there are internal limit switches in the acuator, 1 hour cycles and line power available, Slinky could use a cheap plug-in wall-timer, switching a DPDT 120VAC relay to change the polarity of the 12VDC every 60 minutes.
    Ken
