actuator (dc motor) position feeback
Discussion in 'The Projects Forum' started by wahaha686, Feb 11, 2012.
  1. wahaha686
    Feb 11, 2012
  2. Mark_T
    Member
    Feb 7, 2012
    47
    8
    Whats the overall distance and what resolution do you require?
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    gear or cable a pot to your linear segment.
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    Google "String Pots"
  5. wahaha686
    Feb 11, 2012
  6. BillB3857
    Feb 28, 2009
    2,402
    348
  7. IC-Man
    Jan 3, 2012
    26
    One option would be to count the motor rotation using a small magnetic encoder, like the iC-MA from iC-Haus (http://ichaus.biz/product/iC-MA ). To identify the end position an additional end switch would be needed. The resolution is 6-8bit per rotation and you get forward/backward counts (AB pulses). You may also take a look at this application article: http://ichaus.biz/appnote_magneticsensors .
