Actuator Control Unit
Discussion in 'Power Electronics' started by Otarian, Oct 11, 2016.
  1. Otarian
    Oct 11, 2016
    Hi All...
    I have an 18in linear actuator that I am using to lift a cabinet draw, but when I connect the actuator control unit (ACU) under power the actuator does not work, but the actuator does work when I connect it directly to the DC adapter. Im not sure if the 12DC power adapter is supplying enough power, or if something else is wrong...
    Specs are:
    18in Linear Actuator
    Input Voltage - 12DCV
    Static current (no load) - 0.8A
    Max load-current - 3A
    Ozwerx Actuator Control Unit (with an inline 10amp fuse)
    Input power - 12DCV
    Static current (no load) - 10mA
    Maximum current (with load) - 16amps (8amps/output)
    DC Power Adapter - 12DCV at 2.5amps
    Thanks in advance guys.. :)
  2. Alec_t
    Sep 17, 2013
    5,967
    1,135
    At start-up the actuator needs 3A. That exceeds the adapter rating. The adapter could be protecting itself by shutting down.
    Welcome to AAC!
  3. AlbertHall
    Jun 4, 2014
    2,261
    447
    But it doesn't happen when connected direct. Maybe the voltage drops and upsets the controller.
    Or maybe the controller is defunct.
