Actual gain Vs. Bode plot gain?
Discussion in 'General Electronics Chat' started by Alshatri, Nov 9, 2013.
  1. Alshatri
    May 14, 2013
    Dear all,
    I have the gain @100Khz in bode plot almost=1dB, while the actual gain= 20 log(Vout/Vin)=20 log(3/0.005)= 55.56dB (from the transient values)
    Could someone please explain why I have this weird bode plot gain reading?
    Regards
  2. ronv
    Nov 12, 2008
    3,404
    1,492
    I think it is because the bode plot is expecting an input of 1 volt so the scale is wrong. I didn't draw it up and try it but I think that's it.
  3. Alshatri
    May 14, 2013
    Could you tell me please what is the 1V that are you talking about?
  4. WBahn
    Mar 31, 2012
    18,093
    4,918
    I think the problem might be related to having a resistor whose value is dependent on the signal. I think the AC analysis linearizes things and so I don't know how it would deal with a voltage-dependent resistance.
  5. LvW
    Jun 13, 2013
    674
    100
    Alshatri, when you like to see the gain (Vout/Vin) you must display the ratio Vout/Vin.
    However, your Bode plot shows only Vout.
    Only in case your AC input is 1Volt it is sufficient to display Vout (because it is identical to the gain).
    Remark: I cannot see which resistor value is "dependent on the signal".
    EDIT: Sorry, a sharper look on the drawing has revealed that R3 depends on the input.
