Active resistance
Discussion in 'The Projects Forum' started by madhurendra, Nov 24, 2011.
  1. madhurendra
    Nov 24, 2011
    hi all,
    can anybody help me, how to vary amplitude of a waveform or pulse using micro controller and pushbutton switch. I dont want to use POT.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    You could take a look at the LM13700 transductance amplifier.
    Bertus
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You could also use an R-2R ladder.
    You should buffer the input signal using an opamp wired as a voltage follower.
  4. MrChips
    Oct 2, 2009
    12,622
    3,451
    You could use a digital pot such as Microchip MCP41010 or Maxim DS1267, for example.
