active rectifier (need help)
Discussion in 'The Projects Forum' started by Salma111, Jun 18, 2011.
  1. Salma111
    Jun 11, 2011
    Does anyone know what is an active rectifier? I need some more information about it. Ill use it in my project.
    thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Kermit2
    Feb 5, 2010
    3,838
    961
  4. Salma111
    Jun 11, 2011
    Im rectifying the voltage signal (120 volts)
  5. wayneh
    Sep 9, 2010
    12,368
    3,224
    ?? That sounds like you want POWER at the output, not a signal (information, not power). You need to specify.
    And if you're talking about rectifying mains power, this thread will soon be locked.
  6. Salma111
    Jun 11, 2011
    thats right, I mean the power signal (not information). I need to know more about the active rectifier, and what is the input and output signals of this rectifier.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This is still wonderfully vague. Could you please take the time to look at the links provided and tell us what it is you are interested in doing?
  8. Kermit2
    Feb 5, 2010
    3,838
    961
    You will have very little luck using any 'ideal diode' as a power rectifier, unless you like destroying innocent circuits.
    Look into IGBT devices used in DC conversion schemes.
    Also google SCR's as they may serve your purposes better with high voltage AC and rectification
