Active or passive component???
Discussion in 'General Electronics Chat' started by dhakal_aman, Oct 13, 2014.
  1. dhakal_aman
    Oct 13, 2014
    As per my understanding, all the sources of electrical energy are considered to be active component.If I am right, in LC oscillating circuit, capacitor as well as inductor acts as a source asynchronously. Now, do we consider capacitor and inductor active or passive component in this case?
  2. studiot
    Nov 9, 2007
    5,005
    515
    The term active does not denote a device's ability to introduce energy into a circuit. It is a more complicated concept and there are grey areas
    My electronics dictionary has
    "Denoting any device, component or circuit that introduces gain or a directional functio. In practice any device except a pure resistance, capacitance or inductance or a combination of these three is active"
    dhakal_aman likes this.
  3. dhakal_aman
    Oct 13, 2014
    But transformer is also passive component...!!!! :?
  4. dhakal_aman
    Oct 13, 2014
    As per my view, active components are those which creates energy of its own and have capacity to amplify signal. But, I don't think diodes have capacity to do so. Than why is it considered as active components?
  5. t_n_k
    Mar 6, 2009
    5,448
    783
  6. MrChips
    Oct 2, 2009
    12,638
    3,456
    One thread will do. I will merge the two in one minute.
  7. MrChips
    Oct 2, 2009
    12,638
    3,456
    How would you classify a tunnel diode?
  8. sirch2
    Jan 21, 2013
    1,008
    351
    What is the purpose of making a distinction between active and passive?
    MrChips likes this.
  9. alfacliff
    Dec 13, 2013
    2,449
    428
    a tunnel diode can be either. when used as a regular diode, it is passive, when it is used in its negative resistance state, it is active as an amplifier or oscilator.
    a transformer is a passive componant, it dosnt change or amplify.
  10. MrChips
    Oct 2, 2009
    12,638
    3,456
    There is no reason to use a tunnel diode as a regular diode when the latter will do.
  11. crutschow
    Mar 14, 2008
    13,505
    3,376
    My preferred definition is that the only passive components are resistors, inductors, and capacitors (or variations of that, such as transformers). Thus I consider a diode an active device and don't need to split hairs about whether any other device is active or passive. But, as noted, I see no good reason to get all that concerned about an arbitrary definition.
  12. wayneh
    Sep 9, 2010
    12,391
    3,246
    FWIW, Mouser does not list diodes under "passive components". I could go either way on a diode but the dictionary definition provided by studiot seems to hold.
    When the definition says "gain", would we assume they mean gain>1? A resistor divider provides a gain <1, but surely is not active.
  13. studiot
    Nov 9, 2007
    5,005
    515
    A transistor has no energy of its own, but I know of no one who would say that it is not an active component.
    A photodiode reacts to incident light, and all diodes are photodiodes, if you allow light to enter the junction so it is not unreasonable to classify them as active.
    Of course that brings up the question of transducers in general.
    And, of course, resistors can be transducers (as in strain bridges).
    Perhaps we should have a classification scheme that is more than two way?
  14. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,701
    1,300
    A transformer can have voltage gain or current gain, but not both at the same time - power gain. This places it clearly in the "passive" category. With an external power source, a tunnel diode can produce sustained oscillation, something no LC combination can do, so I see it as an "active" part. In fact, I mildly disagree with the AAC book about all diodes. Semiconductor junction physics are fundamentally different from anything in the R-L-C camp, so I see all diodes as active devices. True, most don't have power gain, but Rs, Ls, and Cs are all variations of the same theme; diodes just plain ain't.
    ak
  15. Chalma
    Member
    May 19, 2013
    54
    I don't know if this is accurate, but I usually go by the model if the component can be affected by ESD then the component is active.
