Active High Pass Filter
Discussion in 'Homework Help' started by skusku, Aug 22, 2012.
  1. skusku
    Thread Starter Active Member
    Aug 9, 2009
    70
    Just a little confused..
    Circuit - http://i46.tinypic.com/23rpvyr.jpg
    3Db cutoff points - http://i48.tinypic.com/sdephh.jpg
    Voltage Gain - http://i47.tinypic.com/9aq0i8.jpg
    This is supposed to be a high pass filter, and according to the question we should set this from 1hz to 30Khz. But when upping the scale to lets say 900Khz it becomes a bandpass filter. Now I dont know if this was meant to be up until 300Khz(typo???).
    We need to get the lower cut off freq which is roughly 295Hz. Now am I to take the upper cutoff freq as infinity(as in ideal conditions for high pass filters) or use the higher 300khz scale and use that 3dB value?
    Last question is the voltage gain: Practical we say Av(dB)=20log*(Vout/Vin) where I got that above graph.
    Can I just use a mid frequency say 10Khz and use that as a value or am I missing something?
    Please help , Im very desperate for all marks I can get, even if its just an extra point.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    It looks very much like a bandpass configuration.
    The presence of C1 gives a zero DC gain.
    At mid-band frequency C1 reactance will be much lower than C2 reactance and if we further assume C1 reactance to be much lower than 5.36k then the voltage gain magnitude is essentially unity [R2/R1] or 0dB.
    As C2 reactance decreases with increasing frequency C2 shunts R2 [with C1 reactance effectively zero] and the gain tends to drop towards zero at ∞ frequency.
    The corner frequencies are notionally about 300Hz and 300kHz.
    I don't understand how you are showing 105dB gain at 1Hz in your attachment.
  3. skusku
    Aug 9, 2009
    70
    Theoretically the gain should be: Av= -R2/R1 = 1=0dB
    But with practical I used Av=Vout/Vin and then it gives that graph which makes me ponder even more. The differences between the two is miles out.
    My input is set at pin 2.
    When i change input probe between R1 and C2 I get:
    http://i49.tinypic.com/11ceici.jpg
    Should the input part be directly at pin2 or maybe even directly at the AC source point?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    You are confused.
    The gain is measured from the AC source terminal to the amplifier output terminal.
    The result should look like that shown in the attachment.
  5. skusku
    Aug 9, 2009
    70
    Tnk, sorry I edited my post because I had a error where I had used the output/output by mistake.
  6. skusku
    Aug 9, 2009
    70
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    OK - I see you edited the image but you are still doing it wrong.
    The gain is measured from the source [V1 active terminal] to the amplifier output pin6 - not from the R1.C1 junction to the output.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Yep - You now have it correct.
  9. skusku
    Aug 9, 2009
    70
    Thank you very much TNK. Really appreciate your feedback! :)
  10. skusku
    Aug 9, 2009
    70
    And now I kind of want to reopen this thread.
    The lecturer made an error on the schematic (wrong value on C2), but i think for now lets keep the values the same and work from there.
    1st let me ask if there is any difference between 3dB points and the upper and lower cut-off freq?
    The question directly states:
    a)Obtain the lower and upper cut-off freq for this filter.
    b) Determine the Bandwidth of this filter.
    C)Determine the Voltage gain of this filter.
    So as posted here: http://i48.tinypic.com/sdephh.jpg
    a)lower cut-off freq = 296Hz
    Upper cut-off freq = 222Khz
    b) Bandwidth = 222.11Khz
    c)Voltage Gain = 0dB
    And the lecturer marked all my answers wrong.....!! Please can someone help me as I don't understand what I did wrong.
    With the change in C2 the upper cut off freq and Bandwidth should change; The lower cut-off and Voltage gain should remain the same according to my understanding. (this also reflects on pspice)
  11. Ron H
    Apr 14, 2005
    7,050
    657
    Were you allowed to use simulation to get your answers? Did you also try to get them analytically?
    The 741 op amp will significantly reduce the upper cutoff frequency, compared to an ideal op amp. Did the original question specify a 741?
  12. skusku
    Aug 9, 2009
    70
    We were suppose to only use simulation to get our answers. And yes the schematic is directly from our practical guide as is with the 741 op amp.
    The only reason I think is a you say the simulation is suppose to differ from the ideal conditions. So why is the simulation giving me those "wrong/ideal" results then?
  13. Ron H
    Apr 14, 2005
    7,050
    657
    If the op amp were ideal, the low frequency corner would be very close to Fc=1/(2πR1C1), and the high frequency corner would be very close to Fc=1/(2πR2C2).
    The 741 has a gain-bandwidth product of 1MHz. This means that, at 250kHz, the open loop gain is only 4, and the output is phase-shifted 90° from the input. When the gain is this low, the op amp is far from ideal, so the high frequency corner is shifted down from the ideal case.
    I don't understand why your answers were marked as wrong. Did you find out why this was done?
  14. skusku
    Aug 9, 2009
    70
    I did try to find out but then I got into an argument with the lecturer and decided before this goes the wrong way I will leave it. The lecturer will probably tell us in a week or two, but trying to speak to him one on one will get me nowhere.
    "the open loop gain is only 4": As this is a single stage does that imply the gain of 4 is low?
  15. mlog
    Member
    Feb 11, 2012
    276
    36
    This is a biquad filter with 1 zero and 2 poles.
    By the way, my analysis is consistent with t_n_k's plot in post #4. There is a zero at 0 Hz and poles at 297 Hz and 297 kHz. It resembles a bandpass filter more than a highpass filter.
  16. Ron H
    Apr 14, 2005
    7,050
    657
    An OPEN LOOP gain of 4 is far from that of an ideal op amp, whose open loop gain is infinite.
  17. Ron H
    Apr 14, 2005
    7,050
    657
    Isn't the zero at the origin?
    skusku likes this.
  18. skusku
    Aug 9, 2009
    70
    Yup sorry I had that part all wrong regarding it being a high pass filter. This is definitely a band pass filter.
  19. mlog
    Member
    Feb 11, 2012
    276
    36
    Yes, thank you. You're correct.
    skusku likes this.
