Active harminic filter Calculations
Discussion in 'General Electronics Chat' started by johnnyb6231, Nov 26, 2012.
  1. johnnyb6231
    Nov 26, 2012
    In regards to the Active Harmonic Filter. How would one size the filter with both linear and non-linear loads on the bus.
    Example: With several non-linear loads with a full load amp rating of 225 Amps @ 480 Volts/60 hz and linear loads of 75 amps. Assuming 35% THD and wanting to be at <5% THD. What would be the proper calculation to find the corrective amps needed for an active harmonic filter.
    Regards,
    Johnny
