Active filter/ Tone control
Discussion in 'The Projects Forum' started by Amagic, Jul 18, 2007.
  1. Amagic
    Jul 18, 2007
    Hi does anybody know how to read the circuit attached, I'm trying to find out how to work out the max and min Gain for each circuit,
    the part that is comfusing me the most is the capacitor. i'm trying to find out how the circuits reacts to various frequecies
    If anybody can help i would be very greatful
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    The circuits are to small to look at. The capacitor has a high impedance (AC resistance) to low frequencies and a low impedance at high frequencies. But I notice that are connections made wrong. Only the feedback network should use the "-" input. The signal should be fed at "+" input if I recall. Unless you want to make an inverting circuit.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    I too found the images too small to read. Hopefully you can take another shot at attaching the images so that we can address your questions regarding the transfer functions of your circuits.
    hgmjr
  4. JoeJester
    Apr 26, 2005
    3,387
    1,211
  5. nomurphy
    Aug 8, 2005
    567
    12
    You can combine into a single op amp, if you also use a low source impedance pre-driver to the tone controls. A quad op amp (TL074) works well for stereo. See attached:
  6. nomurphy
    Aug 8, 2005
    567
    12
    Here are the equations:
    BASS (assumes R24 > R22)
    ~38.1 Hz = fL = 1 / 2pi*R24*C23
    ~284Hz = fLB = 1 / 2pi*R22*C23
    ~10 = AvB = 1 + (R24 / R22)
    TREBLE (assumes R26 > R22+R23+2R25)
    ~8.8K = fH = 1 / 2pi*C25*R23
    ~856Hz = fHB = 1 / 2pi*C25*(R22+R23+2R25)
    ~10.3 = AvT = 1 + [(R22 + 2R25) / R23]
