active filter doubt
Discussion in 'Homework Help' started by prescott2006, Oct 12, 2009.
  1. prescott2006
    Thread Starter Active Member
    Nov 8, 2008
    72
    do the gain waveform correct?but shouldn't it has a -40db drop after the -20db drop,y the curve so smooth?:confused:
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Since it is a second order low pass filter you would expect a 40dB/decade roll-off once you get a reasonable way beyond the cut-off frequency. So your simulation is probably OK.
    I'm not real sure about the -20dB drop issue you have raised - perhaps you need to clarify your question.
    Also keep in mind this type of opamp filter doesn't continue to follow an 'ideal' second order response indefinitely with increasing frequency.
  3. prescott2006
    Nov 8, 2008
    72
    ya,i also want to ask why the filter does not follow ideal response at high frequency.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    You have simulated your circuit with 741 opamp model. This opamp has poor performance and this is reflected in the model. Use an "ideal" opamp model if you want the ideal response.
    Also I think then you are talking about the -20dB drop, you mean the -3 dB drop. But remember one thing. The -40 dB roll-off is the bode plot approximation. Even if this a very good approximation, it is not 100% accurate. And it certainly do not take components specifications into consideration.
