You're on the right track here. Since it looks like your using the Sallen-Key topology, using 50k resistors whenever you can is a good idea. This should give you reasonable values for your capacitors also.Ok, so setting my Capacitors equal to each other then equal to 1. I get the following: This website helped http://www.maxim-ic.com/appnotes.cfm/an_pk/1795
I get:
\(\frac{S^2R1R2}{S^2R1R2+S(2R1)+1}\)
So I figured since I have the coefficient of the S(2R1) term (2.4*10^4) I could set 2R1 equal to that and then solve for R1 getting 12000. But then that leaves me with \(\frac{1}{12000}\) for my R2, which seems strangely low. But, i guess it would make those terms have a coefficient of one..... But It just doesn't seem right. It can't be that easy.
You should realize that setting a capacitor value to 1, means setting it to 1 Farad, an extremely large value. That's why your resistor ends up being so small. Try a capacitor value like 1E-6, 1 microfarad instead. Or, maybe even smaller.Ok, so setting my Capacitors equal to each other then equal to 1...
You can try the guessing game but I think you will be guessing long after the assignment is due. That is unless you have inordinate luck on your side.I'm trying to guess some good values for R1 and C1 that won't give me some really wierd numbers. My professor said it would be easier to pick them that way, instead of having C1=C2, but It's kinda hard.
Familiarity with this problem and three decades of experience in circuit analysis inform me that the best way to approach the solution to the value of "k" given the assumptions I have chosen is to decide which of the two resistors I will use in the analysis. I can choose either one since once I know the value of "k", I will be able to ascertain the other resistor. I choose R1.
This is a system of two non-linear equation with four unknowns. Since these two equations can only be solved if there are only two unknowns, some assumption must be introduced if the system of equations is to be made solvable.
Out of the universe of assumptions, I have chosen the following two:
AND
Step 1:
Plugging in C for C1 and C2 in the above equation and then solving for the product of R1 and C yields:
\(\normalsize{R_1C}\ =\ \Large{\frac{2}{2.4\times 10^4}}\)
Step 2:
From the equation relating R1 to R2, I solve for R2 in terms of R1:
\(\Large{\frac{1}{\frac{{R_1}^2C^2}{k}}}\ =\ \normalsize{5.76\times 10^8}\)
Step 2a:
\(\Large{\frac{k}{{R_1}^2C^2}}\ =\ \normalsize{5.76\times 10^8}\)
Step 2b:
\(\normalsize{{R_1}^2C^2}\ =\ \frac{\Large{k}}{\normalsize{5.76\times 10^8}}\)
Step 2c:
\(\normalsize{{R_1C}\ =\ \LARGE{(}{\frac{\Large{k}}{\normalsize{5.76\times 10^8}}}\LARGE{)}\ \Large{^{\frac{1}{2}}}\)
From Step 3b above, it should be obvious to even the most casual observer that the value for "k" is 4.Step 3:
\(\Large{\frac{2}{2.4\times 10^4}}\ =\ \LARGE{(}{\frac{\Large{k}}{\normalsize{5.76\times 10^8}}}\LARGE{)}\ \Large{^{\frac{1}{2}}}\)
Step 3a:
\(\LARGE{(}\Large{\frac{2}{2.4\times 10^4}}\LARGE{)}\Large{^{^2}}\ =\ \LARGE{(}{\frac{\Large{k}}{\normalsize{5.76\times 10^8}}}\LARGE{)}\)
Step 3b:
\(\LARGE{(}\Large{\frac{4}{5.76\times 10^8}}\LARGE{)}\ =\ \LARGE{(}{\frac{\Large{k}}{\normalsize{5.76\times 10^8}}}\LARGE{)}\)
It should be easy enough for you to plug these values back into the general transfer function equation and verify for yourself that the values you have chosen are correct.Ok, so picking C1= 1uf and R1=10kΩ using the above equations,I get C2=4.18uf and R2=4.1Ω Does this sound reasonable?
Those values come close enough to satisfy one of the equations but not the other other. The challenge is to get the choice of R1, R2, C1, and C2 to satisfy both equations.No, I did not plug them back in. I was guessing some more. But I wouldn't think that they would since they aren't ratios of each other.
Using your method above I chose R1= 1k so R2 = 4k, which yields the C = .83uF
but when calculating them I get 24096.4 = 24000, which is obviously wrong. But not by much. perhaps due to the .03 repeating.
It is these two equations in the insert above that I was referring to when I spoke of the two equations.\(\frac{1}{R_1R_2C_1C_2}\ =\ 5.76\times 10^8\)
\(\frac{1}{R_1C_1}\ +\ \frac{1}{R_1C_2}\ =\ 2.4\times 10^4\)
by Jake Hertz
by Aaron Carman
by Duane Benson
