Activation buttons on 2 way Micro-controller motor circuit
Discussion in 'The Projects Forum' started by rfeyer, Aug 12, 2015.
  1. rfeyer
    Aug 24, 2014
    126
    Hi all,
    thanks to ReloadRon and many others, I have been using the below successfully for several months - TY all for your help.
    To recap: it is a MicroController controlled circuit allowing a 12VDC motor to run two directionally.
    What I would like to add: an Up and a Down button so the motor can be controlled directly at the site where the motor is located.
    Looking at the below circuit, could I simply 'jump' the 1k resistors with a push button switch (added with wide blue lines)?
    Rainer
  2. rfeyer
    Aug 24, 2014
    126
    Anyone?
    Sorry to be bumping, but I blew 2 transistors already so I just need to know if it makes sense the way I applied the switch leads
    Rainer
