Across the line?
Discussion in 'The Projects Forum' started by inwo, Dec 27, 2013.
  1. inwo
    Nov 7, 2013
    2,435
    315
    What is good practice device to protect line input?
    Could be to a transformer or diode/thyrister circuit.
    I'm using a fusable link on the pcb in and out, and a line rated X1Y1 cap across the ac input.
    http://www.digikey.com/product-detail/en/DE2F3KH103MA3B/490-4217-ND/1021453
    It's in a noisy environment. Hand held drill.
    I'm thinking a mov might keep blowing fuse from the noise.
    Noise won't effect the rest of circuit.
    Maybe nothing is best?
    Also have a diode across diode/scr bridge. Corner to corner. Redundant?
  2. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Are you trying to prevent EMI etc getting back on the line or the internal electronics?
    Many of the industrial drives, use a R/L filter (Corcom) network system similar in design as used on the input to PC supplies etc, avail from Digikey.
    For internal DC supplies, a sufficiently large smoothing/de-coupling capacitor across the supply together with a .1μf across the electrolytic should be sufficient.
    Max.
  3. inwo
    Nov 7, 2013
    2,435
    315
    Just trying to protect the diodes and scrs from destruction.
    Just seems like I should have something across the input.:confused:
    Space is limited.
    Maybe the .1 across the bridge instead?
  4. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Many of the bridge/SCR type drives just use a 150v MOV and a parallel .1μf cap across the bridge input and a small ferrite choke in series with the DC load, for the 120vac version.
    Max.
    inwo likes this.
  5. inwo
    Nov 7, 2013
    2,435
    315
    I'm not too far off with the .1 cap then.
    The diodes and scr are 600 volt.
