Acquiring negative voltage without dual rail power supply
Discussion in 'The Projects Forum' started by DrDaniel, Mar 20, 2015.
  1. DrDaniel
    Dec 11, 2014
    Hello everyone,
    We are working with a circuit that implements a dual supply op amp with 5V as the positive rail and -5V as the negative rail. The circuit also needs a common ground. We have a power supply that only ranges from 0 to 12V. What is the best way for us to acquire the -5V that we desire?
    We are using an LM7805 for the 5V, power supply is held at 12V for other uses.
    Thanks,
    Daniel
  2. OBW0549
    Mar 2, 2015
    1,396
    941
  3. mcgyvr
    Oct 15, 2009
    4,798
    979
  4. cmartinez
    Jan 17, 2007
    3,700
    2,802
    Here's another very good chip to accomplish what you want.
