Accuracy vs resolution
Discussion in 'General Electronics Chat' started by embedded.world, Jun 2, 2014.
  1. embedded.world
    Feb 27, 2014
    36
    Can accuracy be bigger than resloution.
    For example if I have device of 0.1V resolution will its accuracy can be +-0.05V?
    Or accuracy is always lesser than resolution?
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Have a look at the attached PDF on DAC's.
    Bertus
  3. ErnieM
    Apr 24, 2011
    7,435
    1,625
    I would agree with this statement.
  4. kubeek
    Sep 20, 2005
    4,687
    805
    Depends on what you´re talking about. For example, you could have a precision current source, that has 1mA increments, but is 0.1% accurate. Then your resolution is 1mA but your accuracy is +/- 1uA.
    But for normal AD/DA converters, multimeters etc. accuracy cannot be better than data resolution, aka step size.
  5. studiot
    Nov 9, 2007
    5,005
    515
    Well it depends how you measure accuracy.
    As always units are all important.
    Resolution is always measured in the same units as the measurand (measured quantity), so
    10 volts measured to 0.1 volts, resolution.
    But accuracy is normally stated as a ratio or % which is a pure number without units.
    This makes the question of which is bigger meaningless.
    But sometimes the % can be translated into the same units as the measurand.
    For example,
    Take an analog meter with a markings at 0.2 volts and a full scale deflection of 6 volts.
    Typically a high quality meter may be quoted at an 'accuracy' of 1% of FSD
    By reading between the scale markings it should be possible to obtain a resolution of half a marking ie 0.1 volts.
    This applies anywhere on the scale.
    Now consider the accuracy at different points on the scale.
    At a reading of 5 volts, the accuracy is 1% of 6 volts ie 0.06 volts
    So the accuracy is less than the resolution.
    So the final reading is 5 volts ± .05 volts ± .03 volts.
    If you read on the lower end of the scale the situation is much worse, because the accuracy is still 1% of FSD and the resolution still 0.12 volts but for a reading of 0.4 volts we have a final reading of
    0.4 volts ± .05 volts ± .03 volts.
    This is why you should always read these meters on the range that gives the highest possible reading.
  6. wayneh
    Sep 9, 2010
    12,374
    3,226
    Statistics play a role as well, although this may be beyond the OP's question. The mean of repeated measurements with an imprecise instrument, no matter how wide the standard deviation, can give a more accurate estimate of the real mean than a single measurement.
