accessing hyperterminal through lan
Discussion in 'Computing and Networks' started by lekshmipriya1989, Apr 10, 2011.
  1. lekshmipriya1989
    Apr 7, 2011
    i have interfaced a temperature monitoring circuit with my pc..through the hyperterminal and i'm able to get the data read on to it..now i want to connect my pc to other pc via wired lan connection..
    i want to know if its possible to access the hyperterminal data from the first pc(the one which has the direct conncetion with the circuit)
    what is to be done?
    will it be possible to avoid GUI (like labview) to share the data..
  2. retched
    Dec 5, 2009
    5,201
    313
    If you can post the data to a "shared" area, the second PC should only have to access it via standard get.
    Just like looking at a web page.
  3. nerdegutta
    Dec 15, 2009
    2,565
    805
    If:
    • the data is stored in a file
    • the directory containing the file is accessible
    Then I think you can use either Telnet or Putty to view the data. You might only need a minimum installation of Linux, with Telnet or Putty installed to view it.
