I want to use a tilt sensor in my project....application is something to do with fuel measurement of a vehicle with a float valve(to measure how much fuel is left in tank) and tilt sensor(to measure the tilt of vehicle ).... the micro-controller takes input from both the sensors,process n decide the fuel %... so which tilt sensor should i go for....also one with analog output or PWM output ??
