Accelerometer Query
Discussion in 'The Projects Forum' started by PhilPense, Jun 27, 2010.
  1. PhilPense
    Jun 27, 2010
    I write as a complete novice interested in advancing a project. One of the elements required is a way to detect Deceleration. Iwould ask if an accelerometer can be oriented to sense this. Much thanks in advance as I await an informed response.
  2. Dx3
    Member
    Jun 19, 2010
    87
    7
    Deceleration is just acceleration in a different direction.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Radio Shack sells a really neat ready to use acelerometer for around $30 USD.
    Here is a link to the device on there their site.
    hgmjr
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    With a one axis accelerometer oriented such that a positive voltage came from an acceleration, then a negative voltage output would indicate deceleration.
  5. Bernard
    Aug 7, 2008
    4,231
    414
    Observation:The RS accelorometer is also a fine tilt sensor, so it seems like it should be kept level during deceleration. The output is an almost 50% duty cycle @ 100Hz signal which varies between 45% & 55%.
  6. nickelflipper
    Jun 2, 2010
    280
    35
  7. hgmjr
    Jan 28, 2005
    9,030
    214
