Accelerometer and latch
Discussion in 'The Projects Forum' started by inwo, Dec 22, 2013.
  1. inwo
    Nov 7, 2013
    2,435
    315
    Looking for a simple accelerometer and latch circuit for a project.
    Single axis.
    Detects kick back from large hand held tool. (drill)
    I'm guessing 10cm to 100cm/sec/sec, but that's a guess pulled out of my hat.
    Latch would open circuit to clutch. 200ma @ 60vdc.
    More details if interest.
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    If I read the intention right, could the initial current be sensed until a certain off load level, then sensor ignored after the initial sense time?
    Using a typical current transformer relay.
    An alternative, a soft start circuit?
    Max.
    inwo likes this.
  3. inwo
    Nov 7, 2013
    2,435
    315
    Possibly, yes.
    For this to fly it has to be simple.
    Like a tilt switch but inertia rather than gravity activating.
  4. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    Depends if you want to go the mechanical/electric route rather than primarily electronic.
    Max.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    I would use a two-axis or three axis accelerometer to measure the sudden torque along the rotational axis of the drill.
  6. Alec_t
    Sep 17, 2013
    5,971
    1,135
    I'd go with Max's approach. Other things (friction etc) being equal, instantaneous current should be proportional to kick-back torque.
