Hello all im currently working on building an AC voltage regulator where by i can control the voltage output, namley voltage amplitude, by adjusting the timing of the gate pulses of the switching device ( i have tried Thyristors, IGBT) the timing of each pulse is determined by the firing angle input into the pulse generator which determins when in the sinusodial cycle each thyristor is "opened".
so far im having very little luck i have created a model that i have some control of the voltage but nothing significant. the plan is to use the regulator to control the speed of an induction motor.
im either looking for help in the form of a working model or possibly a transfer function or some method of mathmatically representing the regulator.
Edit: i forgot to mention that i am building the model in Matlab (simulink)
