AC voltage doubler ?
Discussion in 'General Electronics Chat' started by Externet, Feb 1, 2009.
  1. Externet
    Thread Starter AAC Fanatic!
    Nov 29, 2005
    776
    57
    Is there any circuitry that can double (or triple) AC voltage using no transformer ?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Such circuits would be highly frowned upon around here. Far too many "n00bs" may be tempted to experiment with it, and mains power is nothing for n00bs to play with.
    A transformer is required to safely isolate the circuit from the mains; even just a 1:1 isolation transformer will limit the current present.
    That being said, there are voltage doubler, tripler and quadroupler circuits on this page:
    http://hyperphysics.phy-astr.gsu.edu/Hbase/electronic/voldoub.html
    But don't try to power them straight from the mains.
  3. Externet
    Nov 29, 2005
    776
    57
    Thanks, Sgt.
    No mains involved at all; I mean AC in ; AC out. 12AC to 24AC or 36AC.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, those will do it for you - "sort of".
    A voltage doubler will reduce the available current by more than half, and it won't be quite double the voltage either (due to the Vf of the diodes used).
    A voltage tripler will reduce the available current by more than 2/3, and the Vf of the diodes will become more pronounced in the losses.
    A flyback topology inverter is a good alternative to using voltage doublers/triplers. Not as simple, but arguably more efficient.
    Ronald Dekker's "Flyback Converters for Dummies" is a great tutorial; well worth a few read-throughs:
    http://www.dos4ever.com/flyback/flyback.html
  5. Externet
    Nov 29, 2005
    776
    57
    Those do use transformers, and do not output AC :(
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    My brain must be off completely today. :rolleyes:
    None of those voltage doubler/tripler/quadrupler circuits I mentioned will do it for you; the output will be DC.
