ac transformer for power amplifier?
Discussion in 'General Electronics Chat' started by morphemes, Jan 28, 2014.
  1. morphemes
    Jan 27, 2014
    Say I need an AC transformer that outputs something like 20-0-20 (give or take a few volts). Toroidal transformers are quite expensive. Laminated steel core transformers are affordable, but I can't find any that have a 0v line. Can I just wire the zero volt to earth?
    I've been eyeing these "DIY" 2.1 Channel TDA7294 2x80W+160W power amplifier kits. I have a 19.0V - 0v - 19.0V toroidal, but a match there is not. So, I'm trying to figure out what I need & I've been banging my head against the wall for about a week now.
    Any recommendations, other than therapy? :)
  2. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    What is meant can't find a 0V line? This is just a centre tap of a 40v continuous winding.
    What is the problem with the 19-0-19? If it measures 38v across the outer ends then it is centre tapped.
    Max.
    morphemes likes this.
  3. MrChips
    Oct 2, 2009
    12,623
    3,451
    Many power transformers come with C.T. (center tap) secondaries. That is what the 20-0-20 means.
    The center tap is simply your 0V reference or common.
  4. morphemes
    Jan 27, 2014
    Center-Tapped! Thank you both! For this most arcane of jargons, I am forever in your debt.
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    You're welcome. You just have to ask. Someone here will have an answer.
    Welcome to AAC!
