Current transformers do not care about the primary voltage, only the current. The only voltage of concern is the secondary voltage across the burden resistor as determined by the VA burden rating.VA, Volt x Amp is the power rating of the device, and is directly proportional to any ratio change, as in a transformer secondary etc.
You need to state the voltages you are working at.
If you placed a 100Ω across a supply to draw a maximum of 15va
Or e.g. a voltage of 38.75v with the 100Ω load will be .3875 amps or 15va..
Max.
Thread starter | Similar threads | Forum | Replies | Date |
Mini-power transformer ? | Power Electronics | 4 | ||
S | DIY low voltage transformer | General Electronics Chat | 26 | |
E | Impedance in a Transformer | Homework Help | 6 | |
E | Flyback Transformer + ZVS Driver + Pulse Capacitor Inquiry | Power Electronics | 18 | |
Will this hand made transformer work? | Power Electronics | 8 |
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Jake Hertz
