Ac to dc
pinoyballer
Joined Oct 31, 2007
11
How do you add dc voltage to ac signal. I know how to get rid of it just use a capacitor. For example you have a 2.5 sin(400000*pi*t) input signal then i want to add a 2.5 volts to it using an op amp. the vcc and vee is 5 volts for the op amp i need a circuit to do this. thanks
beenthere
Joined Apr 20, 2004
15,819
Run the AC signal into the inverting input through a resistor. Have the feedback resistor the same size for 1:1 operation - something like 20K is a reasonable value. Use a trim pot to add the offset to the non-inverting pin. The output will have the AC signal running on the DC offset.
Distort10n
Joined Dec 25, 2006
429
You could also use a capacitor and an inductor. The AC input will be through the cap and the DC input will be through the inductor.
It is an easy trick to use in a lab environment. Look up 'Bias Tee.'
