ac to dc
Discussion in 'General Electronics Chat' started by daddy1, Nov 22, 2008.
  1. daddy1
    Nov 22, 2008
    how do i convert ac 12v from a stater to dc 12v by use of a rectifier and 1000 uf capaciter
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. daddy1
    Nov 22, 2008
    a stater is a power generator installed on the cam of a gas motor when spun creates ac voltage we need dc voltage to power light on a dirt bike
  4. scubasteve_911
    Dec 27, 2007
    1,202
    I think you mean 'stator', which is a part of an electric motor/generator.
    Steve
  5. daddy1
    Nov 22, 2008
    sorry electrician not a good speller and yes a stator
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If it's a filament lamp, it's perfectly happy with AC or unfiltered DC.
  7. floomdoggle
    Sep 1, 2008
    217
    Hey Big Daddy,
    Try a bridge rectifier from Radio Shack. They have all kinds of them, and the hook-ups on their web site. The capacitor goes after the rectifier. Happy hunting.
    Dan
  8. daddy1
    Nov 22, 2008
    is this correct
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I'm afraid that won't work.
    See the attached.
  10. DrNick
    Dec 13, 2006
    110
    If the lamp is just a regular light bulb, why not just power it with AC (as beenthere has already suggested)? If the frequency is 60 Hz or higher you wont be able to tell the difference between your dirt-bike lamp and the lights you have at home.
    Also as connected in your drawing, it will "work." It is just a waste of power. The capacitor will couple the AC and act like a low resistance across the terminal, drawing unnecessary power from the PMG (i am assuming you are using a permanent magnet machine), then the diode will just half wave rectify the stator voltage...doing nothing for you.
    However if you want to just use those 2 components and you REALLY REALLY want DC (with poor ripple), put the capacitor on the other side of the diode. If the frequency out of the stator is high enough, full wave rectification is not necessary.
