ac to dc pwm voltage control
Discussion in 'General Electronics Chat' started by raulchandna, Nov 25, 2009.
  1. raulchandna
    Nov 15, 2009
    i tried to make my own voltage controler
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You MUST NOT try to operate your projects directly from mains power.
    You MUST use a transformer to provide isolation from the mains.
    Otherwise, you have a very high probability of being injured or killed by the mains power.
    Please do not try to connect this project to the mains power again.
  3. raulchandna
    Nov 15, 2009
    yes, you are absolutely correct, but please explain.
    when i apply a capacitor on a tranformer regulated 24 volts, supply it works fine.
    then when i appled the same capacitor on mosfet regulated suppy, why this bang happened ?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, you didn't mention that you were using a transformer.
    Please post a complete schematic of your circuit. I can't figure out how it's wired the way you are trying to explain it.
