AC to DC Power Supply - Need Help
Discussion in 'General Electronics Chat' started by Management, Feb 2, 2012.
  1. Management
    Thread Starter Active Member
    Sep 18, 2007
    306
    I am looking for an AC to DC power supply cable of providing 208V to DC output. The DC input to the device can be 9-30V and has a wattage of 4.8 Watts. The 208VAC input would come from a terminal block.
    Any help locating this would be great. Thanks!
  2. gerty
    Aug 30, 2007
    1,154
    304
    [QUOTEThe DC input to the device can be 9-30V and has a wattage of 4.8 Watts.
    The 208VAC input would come from a terminal block. ][/QUOTE]
    Do you require 9-30 v input , or 208 input?
    If all you want is a 208 in and variable 9-30 volt out, there are many off the shelf supplies available. how much current(amps) do you need?
  3. Management
    Sep 18, 2007
    306
    Do you require 9-30 v input , or 208 input?[/QUOTE]
    I need 9-30V input to out device. The source would be 208VAC and go to the power supply. Thanks.
  4. gerty
    Aug 30, 2007
    1,154
    304
    I was editing my post while you were replying, how much currrent do you need? Do you want to build this or just want to know where to buy one?
  5. Management
    Sep 18, 2007
    306
    Well the device needs 4.8 Watts. I am trying to purchase something like this. Thanks.
  6. gerty
    Aug 30, 2007
    1,154
    304
  7. Management
    Sep 18, 2007
    306
    Thanks for the suggestion but I need something small that can vampire off the 208VAC in a NEMA enclosure. The transformer that comes with the device plugs into 110VAC but I can't route a transformer out the enclosure so I only have access to 208V inside the enclosure.
