AC to DC converter
Discussion in 'General Electronics Chat' started by satwraj, Dec 13, 2007.
  1. satwraj
    Dec 13, 2007
    HI......
    i am designing ac to dc converter.
    input ac...240vac.
    output.....+15vdc,-15vdc,+5vdc
    i am using IC TPM10515.i need to connect filter so that i can protect my ic.how to use that filter in output and input section so that so that i can generate required output dc voltage.pls guide me
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Please do not hijack another post. Always start a new topic in a new posting.
    The datasheet does not indicate external capacitors.
  3. pilotshero
    Member
    Nov 29, 2007
    10
    Why settle for only 3 voltage changes in DC when you can have variable voltages in both ac and dc. My schematic is of my own design and cost little, the rheostat is nothing more than an ac dimmer switch but delivers both AC And DC variable voltages. Be sure to use a 120-25v transformer and a good bridge rectifier. If your interested contact me at pilotshero1964@yahoo.com I will e-mail you my shematic.
