Dear Sir/Madam please give any idea/concept for AC Phase detecting either Present/Absent (Logic 1/0)without converting DC volt to detect TTL PIC16F676 microcontroller someone already implemented this products but know i am also implementing this concept on same circuits but I have dont know the logic/ C code for this know I am tried as follows but still i cant able to detecting phase
three phase (RY & B) AC analog inputs directly connected microcontroller pin without converting DC volts / reduced the voltage by using resistor divider circuit series with of 2.2Mohm 0.5watt+5Mohm 0.25watt connected to microcontroller(PIC16F676 pins RA0,RA1 & RA2). and internal oscillator like
#define _XTAl_FREQ 4000000
__CONFIG(0x3FF4)
#define R_phase RA0
#define Y_phase RA1
#define B_phase RA2
#define Three_phase_LED RC0
#define Two_phase_LED RC1
#define Single_phase_LED RC2
#define NO_phase_LED RC3
char phaseRflag = 0; // flag variables for each phase
char phaseYflag = 0;
char phaseBflag = 0;
char single_phase_flag = 0; // used for single phase detection test
unsigned int sample = 0; // used to set "for loop" duration
void main()
CMCON=0x07;
ANSEL=0x00;
TRISA =0b001111;
PORTA=0b001111;
TRISC=0b000000;
PORTC=0b00000;
while(1) // while loop to test phases continously
phaseRflag = 0; // phase flags are set to zero
phaseYflag = 0;
phaseBflag = 0;
// a "for loop" tests the inputs for 20 milliseconds, setting a flag if a logic 1 is read
for(sample = 16000; sample > 0; sample--) // test all phases for at least 20 milliseconds
if(R_phase) // if a 1 is detected on a phase set a flag to 1;
phaseRflag = 1;
if(Y_phase)
phaseYflag = 1;
if(B_phase)
phaseBflag = 1;
} // end of the for loop
// phase tests running as before, except now looking at the flag settings
// test for all phases on ------------------------------------------------------
if(phaseRflag && phaseYflag && phaseBflag)
Three_phase_LED = 1; // RC0 pin connected(Three_phase) LED will Glow ON
else
Three_phase_LED = 0;
// test for phase R and B on ------------------------------------------------
if(phaseRflag && phaseBflag && !phaseYflag)
Two_phase_LED = 1; // RC1 pin connected(Two_phase) LED will Glow ON
else
Two_phase_LED = 0;
// test for a single phase on -------------------------------------------------
single_phase_flag = 0; // set if only a single phase was detected
if(phaseRflag || !phaseYflag || !phaseBflag) // only R_phase is on
single_phase_flag = 1;
if(!phaseRflag || phaseYflag || !phaseBflag) // only Y_phase is on
if(!phaseRflag || !phaseYflag || phaseBflag) // only B_phase is on
if(single_phase_flag == 1) // if a single phase was detected
Single_phase_LED = 1; // RC2 pin connected(Single_phase) LED will Glow ON
else
Single_phase_LED = 0; // single phase LED off
// test for no phases on ------------------------------------------------------
if(!phaseRflag && !phaseYflag && !phaseBflag)
NO_phase_LED = 1; // RC3 pin connected(No_phase) LED will Glow On
else
NO_phase_LED = 0;
} // end of while loop
} // end of main
In this program only
NO_phase_LED = 1; LED is On always....
__CONFIG(0x3FF4)
#define R_phase RA0
#define Y_phase RA1
#define B_phase RA2
void main()
CMCON=0x07;
ANSEL=0x00;
TRISA =0b001111;
PORTA=0b001111;
TRISC=0b000000;
PORTC=0b00000;
phaseYflag = 0;
phaseBflag = 0;
phaseRflag = 1;
if(Y_phase)
phaseYflag = 1;
if(B_phase)
phaseBflag = 1;
else
else
Two_phase_LED = 0;
else
else
NO_phase_LED = 0;
} // end of main
