AC switch
Discussion in 'General Electronics Chat' started by samlightsleeper, Apr 25, 2012.
  1. samlightsleeper
    Feb 22, 2012
    Here's the problem: it's an European house question, I have an outdoor switch which has been wired a long time ago to a pump. Usually we have three wires, a blue, a brown and a green/yellow for grounding. Have been asked to connect a buzzer and a led to the switch directly I would have usually use a AC/DC 12V converter and that would be fine. In the switch there is a only one lead wire, it's blue and lights up the electric tester screwdriver, other wires, the brown and yellow have been connected to the pump directly, totally bypassing the switch. Here's the question: the converters for 220V/12V has input for two live wire, what can I do with an only one lead?
    Thank you in advance, please excuse my amateurism. :)
  2. #12
    Nov 30, 2010
    16,704
    7,342
    I'd say, cut the brown wire and wire-nut onto it. If that leaves the brown to the motor too short, replace it, but I'm American. I've never seen a European wire.
  3. evilclem
    Member
    Dec 20, 2011
    118
    16
    You need to connect between the brown and blue wires as the brown is the active lead and blue the neutral. As mentioned, this will require tapping into the brown wire.
  4. samlightsleeper
    Feb 22, 2012
    I thought so... :( Thanks for suggestions. These are old amateur installations and they were as simple as they could be so the brown wire can't be reached, it's in the wall.
