AC sweep (using PSIM)
Discussion in 'The Projects Forum' started by suzuki, May 10, 2012.
  1. suzuki
    Aug 10, 2011
    119
    Just wondering if anyone here is familiar using PSIM simulation software? I'm trying to do an AC sweep analysis/frequency response but having some trouble. If anybody is familiar with this, I'd like to send them my schematic file to look over.
    Thanks.
  2. Ron H
    Apr 14, 2005
    7,050
    657
  3. suzuki
    Aug 10, 2011
    119
    hmm, unfortunately I don't have access to this block. I am still using the old ac probe/small signal injection method.
    Here is a diagram of the circuit.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    You have exhausted my resources. I don't have PSIM.:(
  5. wayneh
    Sep 9, 2010
    12,374
    3,226
    Those two grounds (AC and DC) aren't actually the same ground are they?
  6. Ron H
    Apr 14, 2005
    7,050
    657
    If they are, then one of the diodes is shorted out.
    I don't think an AC sweep (frequency response) is appropriate for a full wave rectifier. If it is like a Spice simulation, the nonlinearity and harmonic generation will be totally lost, because the DC operating point is established first, then the circuit is linearized around that operating point.
    Suzuki, what are you really trying to do?
  7. suzuki
    Aug 10, 2011
    119
    Yes, that should be the same ground.
    What I want to do is to get the s-domain transfer function of the full bridge diode. Essentially, I have some signal that I want to pass though the diode bridge and see how the gain and phase change due to the diode bridge. Surprisingly, I haven't found any literature on this, so I thought the next step would be to simulate it via ac sweep.
    Not really sure if that makes sense, but it's one of those "why not" things I want to try out. If there's another way I can see the gain/phase, I'd love to hear how.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Presumably you require the Laplace Transform of a rectified sine wave.
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    If you are actually looking at the frequency response of the bridge rectifier plus RC load then that is a more uncertain problem.
    Keep in mind that the diodes may operate in discontinuous mode with the presence of a load filter capacitor.
    A simplistic view is to consider the main AC supply cycle period to be infinitely long in comparison with the sweep frequency cycle period range. One would then consider one opposing diode pair of the diode bridge to be in quasi-static forward bias. In that case one would have the equivalent dynamic diode resistances in series with the load and the sweep frequency source. So one might expect to see a typical single pole -20dB per decade roll off.
    It eludes me as to why one would want to know this ....???
    suzuki likes this.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    I'm with you.
    If it were a lightly cap-loaded rectifier, the diodes would not cut off, but it REALLY eludes me why someone would want to know that. The DC bias is evidence that this capacitor really is for peak holding, as in a power supply.
  11. suzuki
    Aug 10, 2011
    119
    I actually really like this idea. So in each half cycle, you essentially just have 2 diode resistances, the load R and C. I think this should give a pretty good idea of the frequency response.
    I guess to clarify, i had the dc source there as a test for the frequency response. It should be ac going into the rectifier, and the capacitor is mainly for filtering.
  12. Ron H
    Apr 14, 2005
    7,050
    657
    Just remember this equation particularly applies to simulators:
    Garbage In = Garbage Out
  13. t_n_k
    Mar 6, 2009
    5,448
    783
    I tried using PSIM for this 'concept' but obtained a better result using Simetrix.
    The attachment shows the simulation model and two frequency response results for two different bridge AC input voltages - namely 2V p-p and 5V p-p. The result of differing diode dynamic resistances is readily observed with the lower cut-off frequency resulting from a lower AC source voltage.The dB ratio is obtained from the load capacitor back to the AC small signal source sensor / isolator.
    suzuki likes this.
  14. suzuki
    Aug 10, 2011
    119
    Thought I would bump this thread and continue rather than start a new one.
    That is a pretty interesting result, t_n_k. Sorry, I did not see it until now as I've been away. The fact that the response changes so much based on the input voltage seems to make it even more difficult to model or at least approximate the bridge rectifier as a single frequency response transfer function.
    Since this time, what I have tried to do is the following, although I'm not sure if it is correct, so I'd love to have some input regarding my method.
    If we take that circuit you provided, I called the input port V_i and then output of the diode bridge (before R1 and C1) V_d, and lastly the port across C1 is V_o
    As you suggested in a previous post, consider the path through the diode bridge as a series resistor R_d. Therefore, the total output voltage is given by V_o =V_d*Z_o/(Z_o+R_d) where Z_o=R1/(1+sC1R1).
    Would this voltage divider then give the correct transfer function? If you solve for V_o/V_in, you get a single pole, but it doesn't appear that I would get the same DC gain values as you did in your SIMetrix model.
    Thanks for your help.
