AC Superposition Question
Discussion in 'Homework Help' started by cheyenne, Feb 27, 2008.
  1. cheyenne
    Thread Starter Active Member
    Dec 6, 2007
    48
    Use superposition to find the voltage VAB?
    Attempt:
    Firstly I short circuited the voltage source and put an open circuit instead of the current source so there were two circuits to analyse. I thought the best way to do this would be to find the current in AB first in both circuits and then subtract one from the other to get the current. Then use Ohms law to get the voltage AB. I can't seem to get the correct answer.
    For the circuit with just the voltage source it is just a straight forward series circuit so I=Vs/Z
    I = 5 Angle 90/3 Angle 0 = 1.66 Angle 90 Amps.
    Is this correct? Have I made any errors when converting to polar form.
    For the circuit with just the current source I thought it would be best to use the current divider rule. I think this is where I'm going wrong.
    I = Is(-j4/(3+j4//-j4))
    Is this formula correct? If not could someone tell me correct way to do it. I only need help with the currents. Thanks.
  2. mik3
    Feb 4, 2008
    4,846
    63
    For the circuit with the voltage source why you divided only by the value of the resistor? where are the values of inductor and capacitor impedance? you have to include them also in the calculation
  3. cheyenne
    Dec 6, 2007
    48
    I thought the total impedance in the circuit with the voltage source was:
    3 Ohms + j4 Ohms + (-j4 Ohms)
    Does that become 3 + 0j = 3 Angle 0 in polar form. Is this correct? Thanks
  4. mik3
    Feb 4, 2008
    4,846
    63
    you are correct yes
  5. cheyenne
    Dec 6, 2007
    48
    Can you explain to me how current division would work in this example? I think that is where I am going wrong.
  6. mik3
    Feb 4, 2008
    4,846
    63
    lets say you want to find the current through the capacitor
    Ic=Io(current source)*(impedance of the inductor+resistance of the resistor)/
    (impedance of the inductor+impedance of the capacitor+resistance of the resistor)
    ok?
  7. cheyenne
    Dec 6, 2007
    48
    Yes, thanks for your help.
