Hi Guys,
I am working on a project creating an SSR, DC input and AC output.
Input control voltage is 3-30VDC and the relay has to be able to drive a 50-120VAC load having a min current rating of 1 amp. The input and output have to be optically isolated.
The challenge is that I have to design this SSR only using transistors,diodes and opto-isolators and I cant use any electromagnetic relays or any moving parts.
I am wondering if there are any DIY projects I can follow and use as guidelines. Is this a simple project to make? Will I need to mount the components on a PCB board or can I use a small bread board? Anyone have any idea on how many components I might need?
