Could someone please check my work on this question? There are no solutions given and I'd like to check my answer.
Please see figures attached for my work and the problem statement.
I started by computing the impedances of each element.
After doing so, I opened the circuit up and used mesh analysis as well as a few KVL's to solve for the voltages across the elements/source in the open Voc loop.
Once I had obtained all the voltages I simply applied KVL in the open loop and solved for Voc.
After obtaining Voc I found the equivalent impeadance at the terminals of the load by shorting out the voltage sources and opening up the current sources.
With Voc and Zeq I was able to create the Thevenin equivalent and connect it to the load.
The condition for maximum power transfer to the load is that the load, Zl, be the complex conjugate of Zt, which I labeled accordingly.
Is my work correct? Can anyone spot any errors?
Also, how do I determine the power transfered to Zl?
