I am using a guitar pickup to act as an on off switch for a synthesizer I am building.
The pickup produces an analog signal when the string is vibrating, my plan is to turn this into a DC signal with a rectifier, then use a comparator to compare that to a set DC voltage reference. The output from the comparator will be sent to a Basic Stamp 2.
My confusion is where to put all the grounds for this system. In order to see the DC voltage from the rectifier, I need to measure across the rectifier terminals, but the comparator needs to be able to see this voltage in order to make the comparison, and I do not think I can just put the negative terminal from the rectifier into the comparator (as it has the same ground as the pickup's ground).
I have tried a few different ways of connecting grounds, but each didnt seem to work correctly.
Schematic is attached.
