AC Resistance
Discussion in 'General Electronics Chat' started by bcassidy9, Jun 26, 2013.
  1. bcassidy9
    Nov 27, 2012
    5
    Does anyone have any suggestion on how to measure AC resistance? I have a stack up of planar magnetics that I need to determine its AC resistance. I wasn't sure how to go about this right away?
  2. Ramussons
    May 3, 2013
    562
    92
    Use a Wheatstone Bridge with an AC source.
    Ramesh
  3. studiot
    Nov 9, 2007
    5,005
    515
    Planar magnetic whats?
    AC resistance (are you sure you want resistance) at what frequency?
  4. wmodavis
    Oct 23, 2010
    737
    150
    Use Ohms law.
    1. Apply AC voltage set for appropriate frequency to device to be measured.
    2. Measure AC current flowing into the device.
    3. Calculate Z=V/I
    Actually that will allow you to measure impedance not just resistance. If you just want resistance as you asked use an ohm meter.
  5. bcassidy9
    Nov 27, 2012
    5
    Sorry about that.. It is a transformer. And no, I meant to write impedance!
    I could also sweep it and look at the transfer function of the impedance, correct? I guess I wasn't really thinking when I asked this question.
  6. #12
    Nov 30, 2010
    16,705
    7,358
    That happens so often that we're not surprised.
    Take a few minutes and sort out your needs.
  7. studiot
    Nov 9, 2007
    5,005
    515
    They usually are.
    But you still didn't specify frequency.
    Audio? Radio? Microwave?
    Excellent advice!
