Have a question: the attached (admittedly rough) circuit is a layout for converting 5VDC to 240VAC (60hz, around 40VA full load), +/- 15% on the output voltage. The driver circuit puts out 40% duty cycle square waves to drive each power MOSFET (T1 is a small torroidal transformer, originally 240V primary & 24 VCT secondary, 50VA).
The problem I've encountered is that with no load, the output of the transformer is around 280VAC, but with full-load saturation I get around 190VAC. I had the idea to rectify the output of T1, use a split resistor network to drop it down & feed it into the feedback line of the switcher, but after burning out 2 chips I realized that either the switcher wasn't seeing the proper feedback & overloading itself, or induced voltage spikes was burning it out.
I know there are voltage dependent resistors out there, but would they be responsive enough to feedback-adjust the switcher, or is there another clever way to achieve regulation?
