AC Power Worksheet - Q39
Discussion in 'Homework Help' started by Spoon, May 16, 2010.
  1. Spoon
    May 18, 2009
    12
    I'm currently doing the AC power worksheet on this website, found at url
    http://www.allaboutcircuits.com/worksheets/acpower.html
    When calculating the capacitor value I keep getting exactly double the value.
    I calculated the initial power factor to be 0.707 (lagging), which agrees with the solution.
    The reactance of the inductor is Xl = 1.0824∏.
    Xc = 1 / (2∏fC)
    therefore C = 1 / (1.0824∏*2∏*60)
    C = 7 . 8 * 10^-4
    C = 780 uF which is exactly double the required value of 390uF
    Thanks,
    Steve
  2. retched
    Dec 5, 2009
    5,201
    313
    You must be missing the final C=(C*.5) in the equation ;)
    What 'Question #' in the sheet are you referring to?
  3. Spoon
    May 18, 2009
    12
    as stated in the title, Question #39 ... thanks
  4. retched
    Dec 5, 2009
    5,201
    313
    Jeez, I cant read today..or yesterday.. I apologize. Gimme a minute.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    If you were placing C in series with the load then 780uF would be correct. In the parallel placement you only have to compensate for the reactive part of the load current - 390uF is correct in that case..
    Spoon likes this.
  6. Spoon
    May 18, 2009
    12
    Thanks, "only have to compensate for the reactive part of the load current". Was doing this wrong, silly mistake. I agree with the answer now
