If the equipment has a mains transformer - that has reactance that presents a particular impedance at 60Hz, higher frequency will increase the impedance and reduce the current draw - it may not pass enough power to the load for correct operation. A higher frequency will also induce more eddy currents in the core laminations - they may get hot!Some AC power supplies have a built in oscillator that can change the Line frequency to 60hz, 120hz, 400hz, 800hz. Can I power a circuit board that is designed for 60hz and power it up with 400hz or 800hz or power a circuit board that is designed for 115 at 400hz and use a regular power supply at 115 vac at 60hz? What would I have change in the design to power a circuit board that is designed for 115vac at 400hz to work with a power supply that is 115vac at 60hz? is there any problems or it will work?
If you have devices designed to run off a PSU - plugging them into 115V 60Hz will result in a fairly loud bang.No the circuit boards under test don't have a power supply, the power supply circuit is disconnected or it needs an external power supply 115vac at 400hz
I don't own an AC power supply 115vac at 400hz.
That is why I am asking If i power up these circuit boards using a AC power supply at 115vac at 60hz what will happen.
The circuit boards don't have a power supply board. But they use an external power supply that is 115vac at 400hz
If I use an external power supply at 115vac at 60hz to power up these circuit boards what will happen?
The DC gets converted by the circuit. It converts 115VAC at 400hz into DC voltagesThe boards don't have a power supply. Do they have DC inputs that are provided by the external power supply that is 115vac at 400hz?
Such as...?Wow its been a long time since I saw a thread with so much misinformation about basic power supply components and how they work together in a simple circuit.
Such as lumping a bunch of unspecified circuit boards into a single line of questioning, each needing a different frequency from DC to 800 Hz, and repeatedly asking for one answer to fit all the boards.Such as...?
by Jake Hertz
by Aaron Carman
by Aaron Carman
by Duane Benson
