Ac peak current meters
Discussion in 'The Projects Forum' started by eleceng16, Feb 14, 2013.
  1. eleceng16
    Mar 26, 2012
    6
    I've read about instrumentation to read ac RMS values (with rectifier instruments/ moving iron ... ) but how is it possible to directly read an ac peak current value?
    Thanks :D
  2. crutschow
    Mar 14, 2008
    13,505
    3,383
    Rectifier instruments generally read peak values, not RMS.
    In that vein, you use a rectifier and capacitor (to hold the peak value) to read the peak of an AC signal. If you can't tolerate the 0.6V or so drop from the rectifier (diode) then you can use a precision peak hold circuit using an op amp, with the diode in the feedback loop to essentially cancel the forward drop from the diode.
  3. #12
    Nov 30, 2010
    16,704
    7,354
    google: precision rectifier
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Or do it digitally. Take a lot of samples per second and display the highest sample(s).
